Icon Sizes
I have created some of my own icons in 16px and 32px.
When they are in the Ribbon (first image below), the 32px ones are the same size as the built-in icons.
But when I create a toolbar (second image below), they are smaller.
In the first image (from the Ribbon), the two on the left are created by me; in the second image, the bottom icon is built in, and the two above are mine.
As you can see, they are both smaller.
Does anybody know why?
I really am not sure but this is some lines in my toolbar, see the 16 & 32, change 1 only and see what it does.
ID_Matchprop [_Button("Match Properties", RCDATA_16_MATCH, RCDATA_16_MATCH)]^C^C_matchprop
ID_Erase [_Button("Erase", RCDATA_16_ERASE, RCDATA_32_ERASE)]^C^C_eraseDoes vertical v's horizontal make any difference ?
An update on how I resolved this issue.
I ended up increasing the bitmap (.png in my case) to 128px.
I noticed that, depending on the toolbar size, the size of the custom bitmap icons changed.
There was no difference in the icon sizes between built in and custom when I had the setting set to small icons (sadly on a 4k monitor, they are too small to be useful to 60-year-old eyes).
When I tried 64px they were the correct size as built in (using the large icons setting), but were still a bit fuzzy, so I tried 128px and they are perfectly acceptable.
Whether this is my setup that is causing this, I can't say, but it works and worth sharing.
Thanks, AlanH, for giving me a clue as to what this might be, as I remember seeing in one of your posts about using icons larger than 32px, so I gave it a try.
1
