V25 Text Font[Arial] Not Working
Ubuntu V24 BricsCAD V25 Trial. I opened up one of my files and the text is showing up as 00000. The numbers appear to be working but not the letters.
Must be some font problem? I changed the font to romanc.shx and the text display is correct.
Font [Arial] is not working for letter characters.
This image shows the same file with V23 vs. V25.
Fixed the problem like this, unfortunately this is specific to only one drawing.
How to fix the default [Arial] font?
- Type
STYLEin the command bar and press Enter to open the Text Style Explorer dialog box.
- Locate the
Standardstyle (or create a new one) and change its Font property to your desired font.
- Click OK to save the changes to the Text Style.
0 - Type
copied this folder from V23 to V25, fixed the problem
/usr/share/fonts/truetype/freefont
1
