TIN surfaces on BIM section plans
Starting to learn a bit about bricscad TIN surfaces and I noticed that they don't seem to apear on Bim section plans!
The fact is I can convert to solid, but then I have ugly triangles and loose the power editing tools…
How do you manage to have TIN surface contours on bim section plans?
  • pedroloureiro
    edited September 2025
    Ok. I found out the problem.
    The TIN surface is on a xref.
    And bricscad section does not recognize tin surfaces inside a xref file.
    If I copy it to the master model it works as expected.
