Modify Block attributes values from a csv file
Dear All,
Does anyone can help me to write a lisp code to update blocks attributes values from a csv file ?
-My csv file will be like :
BlockName;Layer;KeyAtt;KeyattValue;Att1;Att1Value; Att2;Att2Value; Att3;Att3Value; Att4;Att4Value; Att5;Att5Value; Att6;Att6Value
Block1;Layer1;Att0;XXX;Att1;A1; Att2;A2; Att3;A3; Att4;A4;Att5; A5;Att6;A6
Block2;Layer1; Att0;YYY;Att1;B1; Att2;B2; Att3;B3; Att4;B4;Att5; B5;Att6;B6
Block2;Layer2; Att0;ZZZ;Att1;C1; Att2;C2; Att3;C3; Att4;C4;Att5;;Att6;C6
Block3;Layer2; Att0;GGG;Att1;D1; Att2;D2; Att3;D3
- Lsp code Bricscad v22
-The window to select the CSV file will be displayed and positioned from the path of the DWG file.
-All lines must read from line 2 of the csv file
-Some attributes values may be equal to 0.
-Blocks contain variables attributes (quantity and names)
-The lsp code should not be interrupted by any prompt (even if the block itself contain attributes with prompt)
-The code will only apply to blocks from model tab (no modification on layouts)
-Case 1 : If several blocks meet these three criteria (BlockName;Layer;KeyAttValue): display a warning message and continue to the next line of the CSV file.
-Case 2 : If no blocks meet these three criteria (BlockName;Layer;KeyAttValue): display a warning message and continue to the next line of the CSV file.
-Case 3 : If a single blocks meet these three criteria (BlockName;Layer;KeyAttValue): Modify attributes values of
-A log will mentioned all ignored lined (Case 1 and 2) and the quantity of updated lines (Case 3)
TY for your help
Can be done direct from Excel no need for a csv.
Need a dwg and Excel for testing, code posted many times.
I can not do till Tuesday..0
