Fonts Missing on MacOS
I thought I share this solution when you are missing Fonts which are installed on macOS:
Dacian Macarie 08-10-2025 15:40 UTC
Hello Thomas,
If the fonts are installed on the macOS (they are pressent in the Font Book app), then please try the following:
- In the Finder, use the "Go" menu, then "Go to Folder…" and enter "~/Library/Application Support/Bricsys/BricsCAD/"
- Rename "V2xx64" to something else.
- Then open BricsCAD again, this will force the new instance to create another Support folder
And: - Make sure that any BricsCAD windows are closed
- In the Finder, use the "Go" menu, then "Go to Folder…" and enter "~/Library/Preferences/.bricscad"
- Rename the config and reg files ( in this way BricsCAD settings will be restored to defaults )
- Start BricsCAD (a new config file will be created)
The Second step resolved the font issues on my old Imac running on Big Sur
1
Hi! I have followed your steps but I was not successful. I have version 22 still running since I am only willing to upgrade to an Apple Silicon native version. The use of macOS system fonts broke with the update to macOS Tahoe. I would be very happy for any further assistance to fix this problem.
