Rounding to whole number
Hi There,
I'm trying to set inputs to round to the nearest whole number but am having no luck.
Currently when I draw a new line or rectangle etc, the dynamic input shows and resulting line creates the line length to two decimal spots, eg 1111.23. I need this to be automatically drawn or snapped to the nearest whole number, eg 1111.00 (actually drawn to .00, I don't want to just set Linear unit precision to 0, but still be able to draw a line that's 1111.4562 and I just can't see those decimal places).
I have this issue every time I update Bricscad or do a fresh install and can never remember the correct settings. I've tried adjusting every unit unit setting I can find in settings. DIMRND doesn't seem to change anything and I can't remember the other setting I've used before.
Any help would be appreciated. Thanks,
Ben
Hi Ben,
Try using
SNAPUNIT: 1,1
SNAPTYPE: 0
SNAPMODE: 1
That should achieve what you are after.
Cheers.
