Link attributes to parameter.
How do I link an attribute to a parameter so that after adding a block with this attribute, if I enter the value = when inserting the block, it overwrites the attribute = and thus changes the length of the inserted block?
Via a lisp you can do this by selecting an attribute, enter a new value, the dynamic block is updated. Or again using a lisp to insert the block and update the length. Something like this.
;; Set Dynamic Block Property Value - Lee Mac
;; Modifies the value of a Dynamic Block property (if present)
;; blk - [vla] VLA Dynamic Block Reference object
;; prp - [str] Dynamic Block property name (case-insensitive)
;; val - [any] New value for property
;; Returns: [any] New value if successful, else nil(defun LM:setdynpropvalue ( blk prp val )
(setq prp (strcase prp))
(vl-some
'(lambda ( x )
(if (= prp (strcase (vla-get-propertyname x)))
(progn
(vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
(cond (val) (t))
(vlax-invoke blk 'getdynamicblockproperties)
)(defun c:insdyn ( / pt obj blkname)
(setq blkname (getstring "\nEnter block name " T))
(setq pt (getpoint "\nPick a pt for block "))
(command "-insert" blkname "s" 1.0 pt 0)
(setq obj (vlax-ename->vla-object (entlast)))( LM:setdynpropvalue obj "Distance1" (getreal "\nEnter nmew length "))
(princ)
I tried but without good results.
Bricscad cannot create dynamic blocks. or I miss something?
In the parametric block I tried to give a 2d constraint and a parameter and also the stretch function, all 3 at the same time also separated, just parameter or stretch, but my bricscad can't find parameter to change.
For now, the only option is to create a dynamic block in AutoCAD and use it in BricsCAD.
Or is the way how to create dynamic block in bricscad ?
Hi @Kardo , in V26 "Commands for creating dynamic blocks with actions and visibility states are available under experimental mode except in the USA region where it is not supported.
A BEDIT session can now run in two mutually exclusive modes depending on the type of block:
- the preexisting parametric block editing mode still exists and it disallows editing and creation of dynamic block.
- A new dynamic block editing mode allows creation and editing of dynamic blocks and it disallows editing and creation of parametric blocks.
- You can edit static blocks in both modes. Once you edit a static block to include dynamic or parametric features does the next BEDIT session for that block become locked into a mode."
