activatesectionview command issue
Hello
With the new V26 release I created a section entity of slice type. After this i tried to switch to a perpendicular view with the activatesectionview command. but nothing happens. The entity was detected after calling the command, but no reorientation is applied.
Any hints if there are some settings to change to make this work?
Thanks
  • Lyubov Osina
    edited October 2025
    Do you run Activatesectionview command on the Model tab? I can reproduce missing reorientation in the Layout with a locked viewport (and this is an expected behavior, as viewport is locked), but on the Model tab I didn't find the influencing settings yet.
