v26 SHEET SET MANAGER KEEPS CLOSING
Every time I open the sheet set manager and open a sheet, the SSM closes and minimizes and I have to open it again. There is also another bug that happens if you left click the SSM icon twice, the SSM would move out of the window you have it in and and would get buried under that same window and you can no longer see the SSM but it is there.
Hello.
I couldn't reproduce the issue related to SSM minimizing and closing.
I tested with V25 and V26.If the issue occurs with every sheet set file, something to try would be to create a new user profile an test again.
If this doesn't work, you could consider a clean installing.When double-clicking on a docked panel icon, the panel gets undocked and is displayed as a floating panel.
If the usual behavior is different than this, then, a clean installing could help here too.0
