Superscript not printing
I have the Registered symbol as a superscript that displays in my dwg but not when I print to PDF or to a printer. The wording is Mtext and I used the Romans TTF font and copied and pasted the registered symbol into my Mtext. I used the ^ and stack fraction to get the superscript. it looks just like I want it to. But it will not print. I believe it's the font but does anyone have a reason why or a work around?
Hello.
Indeed, the problem is the font.
RomanS doesn't include the ® symbol.
Inside Bricscad, the symbol is visible, but it uses a font different than RomanS.The solution is to use a different font.
I am not sure what font is just like RomanS.You could experiment with light font, like OpenSans Light for example.
It is a little thicker and requires to use a the Distributed alignment combined with a certain MTEXT width to look like RomanS.0
