Copy and paste between drawings does not work
I have an issue with copy and paste between different drawings as it does not work especially since I have done an update to the latest version.
  • Which command are you using to copy to the clipboard? If COPYBASE, are you remembering to pick a base point?
    Do you execute it by typing the command, or by using an alias, keyboard shortcut, etc? If so, did the CUI file that came with the update assign a different meaning to that alias or shortcut or whatever?
