Attirbuets not moving in dynamic blocks
Hallo
I have 2 questions related to dynamic blocks :
  1. I am creating dynamic block with bricscad 26 and I cannot seem to move the attributes in the dynamic blocks using a stretch action. I have to attsync all attributes to have them in the new position. This is not consistent with Autocad blocks where attributes are stretched and moved without attsync. Is this correct ?
  2. once I have setup an action and a parameter, there is not way to edit their properties, such as editing the stretch area or elements affected. This is available in autocad with a double click on the related parameter or actions. Is there a way to achieve this in brics cad ? now we have to delete and recreate the actions and parameters
thanks
Luca
  • I'm having the same issues with attribute text not moving when you pull the grip, it's not working the way it should and you shouldn't have to attsync everyblock when you stretch them.
  • I dont use dynamic blocks much but have you tried a couple of ideas like constraining the attribute a fixed offset from an edge, or make a circle with a radius of 0.0000001 then adjust the distance from the circle to your attribute based on say a ratio of a distance eg d5=d4/10.
