snapping in bubble views bug
Hello, when i am in a bubble view and trying to draw directly to the point cloud with snapping to nearest point on, drawing a line/polyline does not snap to the right location. For drawing points it works, however for linear features it does not.
Furthermore, is there any way to see the cad elements in the buble view? I can seem to see any element on these views.
  • i'm using bricscad pro v26
  • Hi,
    Normally you should be able to draw lines by clicking in the bubble viewer. However, drawing near edges can result in unexpected snapping.
    The bubble viewer only shows point cloud data. Please create a support request if this is an important feature for you.
