Manipulator object rotate in opposite direction v26
Anyone else notice this behaviour with the Manipulator?
Select object, click the red rotate arc, pull in the direction of desired rotation, type in 90 degrees, notice every time it rotates in the opposite direction. User has to perform again, this time click arc drag in direction then enter 180 to get the object where we intended in the first place.
