Draw order selection
Got another one for you folks, Draw order.
In ver 2025 you could select items with pick or select similar and click bring to front or send to back. In ver 2026 it cancels your selections and asks you to select what to send to back or front, you can't even select previous.
Is there a setting i am missing, My pickfirst is set to 1, draworder is set to 3, any suggestions?
Thanks
  • Lyubov Osina
    edited December 2025
    This is a known issue, which should be corrected by developers soon. DRAWORDER tools don't work properly when run for preselected entities from QUAD, RIBBON, Tools menu or Context menu. But DRAWORDER command works correctly when is run from the command line.
    As a workaround you can try to set NEXTFIBERWORLD=1 (type it in the command line) and restart the program (this resolves the issue for preselected entities).
  • That workaround does the trick.
    Thanks for quick response.
  • You are welcome )
  • OK strange after changing to NEXTFIBERWORLD=1 the draworder worked but then i had 2 crashes and the only thing i changed was that setting. The program just locked up and then just shut down. First time was editing text the second going into paperspace.
    I have reset the NEXTFIBERWORD to 0 and so far no lockups.
  • The draw order problem is corrected in the recent V26.1.07, which is released yesterday.
  • OK thanks i will update
