Changing wall composition
I'm modeling a building, and when I built the walls, I applied a specific wall composition. Then I changed the thickness of one of the wall insulation layers, but I don't see that it's been updated in the model. How can I see that change reflected?
The solution I found was to drag a different wall type onto each wall, and then drag back the wall type I had previously modified. This way I could see the change, but it doesn't make sense.
Select the Wall
_bimupdatethickness
Ok! Thank you, I didn't know about that command. Now I have another question, is there a way to update all the walls at once instead of having to select them individually? I've noticed that if I forget to select one, it retains its old composition.
Not that I know of.
I wonder why Walls do not update automatically. In my other CAD they do (With options from which side/center to shrink/expand)
At least as long as long the Composition does not contain a variable Ply.
