3D parametric component with 2D symbols
Hi guys.
I am learning how to create custom parametric components. I have this box with width, lenght, depth and elevation and with it´s 2D representation on the "floor". Everything is working fine.
Now I want to add this magenta symbol so that it changes it´s size along with the size of the box (something like the window swing symbol).
Please any hints how to do that? I was trying to understand how the window swing symbol on the windows advanced components is created, but I have no clue how it was created. I tried to use "coincident" but with no success.
Thanks
You could create the triangle portion as a block. This allows you to describe in 2D (X & Y plane) using 2D parametric tools. When you insert it you can place it in the vertical plane per your image. You can use 3D constraints to position this block.
CAD Concepts Ltd
