POINTCLOUDCLASSIFY
Following the install instructions of this link in V25 . When I try to classify it just opens this link again. When I did the same for V24, the classification worked.
Any help would be much appreciated.
You need to download and install the classifier libraries. You need to do this for each new BricsCAD release.
I've placed the .DLL files in the install folder as well as PCC models in the UserDataCache folder and re-started V25.
Hi Simon,
The software is re-directing you to the help article of v26, which uses a separate set of DLL files for the classifier.
the following link contains the v25 dlls
Thanks Omid, very much appreciated. Looking forward to testing it out and later comparing with V26. Cheers
