Issues with Installing BricsCAD on MacBook Air (T2) with Kubuntu 25.10
Hello everyone,
I have several years of experience working with .dwg files, and recently I switched to Linux and started using BricsCAD. Now, I’m trying to use my old MacBook Air with the T2 chip, running Kubuntu 25.10.
Unfortunately, when I try to install the latest version of BricsCAD, either via the terminal or Discover, the installation completes successfully, but when I try to launch the application, the icon appears briefly and then disappears after a few seconds. I’ve also tried installing older versions, but none seem to work.
I’m unsure whether this issue is related to drivers (I can only use open-source drivers for the Intel UHD 617), the T2 chip with Kubuntu, or if there’s another underlying cause.
Has anyone had experience using BricsCAD on a MacBook Air with the T2 chip and Kubuntu? Any suggestions or ideas would be greatly appreciated.
Thank you in advance!
P.S.: I’ve already searched on Google and the forum, but I wasn’t able to find any relevant information.
  • Running Zorin 18 and no problems with anything. It's running on an i5 ThinkPad. It's runnig pretty well but will crash on large files (35 MB) does it.
