Custom standard part: Elbow
Dear all,
to share for others:
Recently I have generated a custom standard part using the -BMHARDWARE command as documented in the docs.
Defining the "B: Center to end distance" I ran into some trouble. I figured that the value B equal the distance OP (red), whereas the elbow goes MP along the radius R. For an elbow DIN2605 type 3 the radius equals 1,5xOuterDiameter, which in the case of DN1200x12,5 is da1220.
A functional sample may thus read as below and may be transformed into a part using -BMHARDWARE option create Custom.
NAME: "Bogen Typ 3 25 Grad"
CATEGORY: "Elbow"
PATH: "Piping;Elbows"
STANDARD: "DIN"
DESCRIPTION: "DIN 2605 Bogen Typ 3 auf 25 Grad gekürzt" EXPOSED_PARAMETERS: "PartNumber" "Size" "OuterDiameter" "Thickness" "Schedule"
INITIAL_VALUE: "DN 1200 x 12.5"
LENGTH_MEASUREMENT_TYPE_PARAMETERS: "OuterDiameter" "Thickness"
MATERIAL: "Steel" "PartNumber" "Size" "UNIT" "OuterDiameter" "Thickness" "Schedule" "B" "DEG"
"DN 1200 x 12.5" "DN 1200" "MM" 1220 12.5 "" 405.70 25.0
Best
Seb
