Using Civil Survey, I can not explode Section views and Section
in Linux
I tried to use EXPLODE and BURST but only disappear everything.
How to extract the Civil Survery objects info to others drawings?
Did you try the simple "Explode" it converted the profile into a Pline.
1 -
Yes, EXPLODE it worked for me after many tries, but other objects and text in the section and section view (Civil objects) can not be exported or EXPLODEd
1
There is a known issue with exporting section view via CIVILDWGEXPORT. It's on correction at the moment.
1
