Bricscad wont start on Kubuntu 25.10
BricsCad 26.1.07 installed with no errors as far as i know. After a reboot, i tried starting the program and it never starts. Tried using X11 desktop but no joy as well. please help asap. thanks
KDE 6.4.5
KDE Framework 6.17.0
QT 6.9.2
Kernel 6.17.0-8-gentric (64 bit)
I am using Wayland currently
8x intel core i7-6700T cpu @2.80gz
16 m memory
intel hd graphics 530
HP
Launch it from the terminal and then post the output. If you have SE enabled you might need to adjust to allow for certain libraries or you are missing some dependencies.
EDIT. I see Ubuntu uses Apparmor, try googling "ubuntu apparmor program not launching" and try the first solution which is
sudo aa-complain /path/to/binIn OpenSuse i had to do
sudo execstack -c /opt/bricsys/bricscad/v26/lib*.soand
sudo zypper addrepo https://download.opensuse.org/repositories/home:alvistack/openSUSE_Tumbleweed/home:alvistack.reposudo zypper refreshsudo zypper install libxml2-2To get Bricscad v26 to launch.
Or you could disable SE if its enabled.
BTW. running under Wayland ok.
1
