Radius or angle value ?
Hi everybody,
Is there a simple way to get circle radius or angle value in 3D mode ?
Those function exist in Autocad but in Bricscad i can't find them ?
Thanks in advance,
Best. Fredodb.
Hello.
You could experiment with using the MEASUREGEOM command in V26.
With older versions, MEASUREGEOM is not implemented.
In this case, only the data in Properties panel is available.1 -
Ok. Thanks for the advice.
I'll try and get back to you.
Thx
Fred
