How can I get the attached file Layout?
I can not same layout like do CIVIL3D in BricsCAD Civil for terrain profiles, I mean add labels to Vertical Alignment Views, modify the presentation but linked to coordinates from Horizontal Alignment, etc.
What can I do?
  • You can import a Layout from the xref'd file, or from any other .dwg file.
    1. Right-click on any Layout tab, and select "From template..."
    2. Change the "Files of type:" setting from "Drawing Template (.dwt)" to "Standard Drawing File (.dwg)".
    3. Browse to the folder it's in, select the file, and click on "Open."
    4. Select the Layout you want to import and click on "OK."
  • the file is a CIVIL 3D dwg, and have linked data to objects, I mean when a line is moved others data and that table is updated, I found BricsCAD support some objects, but not all. I think I am missing something.
    So, How can I do add labels and Alignment View for civil3D objects?
