Issues with dimensions
Hello,
I am experiencing issues with dimensions in the layout.
Dimensions are not displaying correctly.
I have attempted to use the DIMLFAC and DIMASSOC commands,
but without success.
Could someone please assist me with this?
Kind regards,
Adnan
  • Hello.
    The first step could be to use the AUDIT command.
    It seems there are a few errors in the drawing.
    Further, the existing dimensions look like they are disassociated.
    Also, some overrides have been applied - for example the dimensions are no longer annotative.
    A solution could be to recreate the dimensions.
    Otherwise, you could experiment with using the DIMREASSOCIATE command.
    After that, some repositioning might be required.
