Group editing
BricsCAD Pro
When I follow the procedure to remove certain entities from a group, and then leave the group command, all of the entities are still attached. Am I doing something wrong or is this a bug?
  • It works for me in V26. Do you use a GROUP dialog or command line version? If the dialog, how do you leave it? OK should be pressed to keep changes.
