New Lookfrom icon not as versatile as the former
I discovered that when using the 8 top/down corners(26 directions) option for the lookfrom icon I cannot access some view angles with the new icon as with the former. Pls will this be improved, I find those angles useful to my workflow. I've attached photos to describe the situation.
Thanks.
With a new Look From you need to select a corner for angled views, while selection of face allows to choose standard orthogonal views.
1 -
Not using latest versions, but can see what Jtlive is not getting. Can you click midpoint of a vertical edge, to get a 45o horizontal view?
The new lookfrom is a work in progress. Some features seem to be missing, such as using the CTRL key to switch between selecting top or bottom type views.
If you really can't work with the new lookfrom, then you can turn it off by setting USENEWLOOKFROM = 0
When changing this variable you will need to close and restart BricsCAD as part of making the switch.
CAD Concepts Ltd
My point exactly,
Thank you0 -
That's ok, then I look forward to an improved lookfrom view in a coming releases,
Thank you0
