Using Extrim in a lisp function not manually
Inside the Express tools is Etrim a great trim function. In Acad the Extrim.lsp is all exposed but errors when used in Bricscad, with a missing function.
Ok if you have express tools loaded you just need to type EXTRIM select a cutting object then a side for cut. Inside lisp you can also run Extrim by the following.
(setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
(vla-sendcommand acdoc "extrim !ent !cpt ")
Full test code
;Bricscad
(defun c:wowxx ( / ent cpt acdoc x)
(setvar 'pdmode 34)
(if (= acdoc nil)
(setq ss (ssget (list (cons 0 "LWPOLYLINE"))))
(repeat (setq x (sslength ss))
(setq ent (ssname ss (setq x (1- x))))
(setq cpt (osnap (vlax-curve-getStartPoint (vlax-ename->vla-object ent)) "gcen"))
(command "point" cpt)
(princ)
(C:wowxx)
In this mage can see the points made but only one rectang is cut.
If you run the ssname and get a single entity and cpt and repeat that part of the code it all works. I am not sure if problem is calling EXTRIM each time. One thing I did discover is you can call it after using at least once with (etrim ent cpt) in Acad you (load "extrim") then use the defun method.
I contacted support but got only a part answer the second part was if you have a maintenance agreement we will help more. I am on V25 and at moment do not intend going to V26. The express tools are loacted in Express directory and are DES files.
Hello.
You could experiment with using (command) instead of (sendcommand).
This seems to be more suitable in this case.
Meaning:
(command "extrim" ent cpt)Also, in my testing, I temporarily set OSMODE=0.
"gcen" worked better with this setting.0 -
In case any one read this post and was interested, there is just something a bit different with Bricscad Extrim, compared to Acad, tried all sorts of combinations.
The final working solution was to write a script with every pline entity handle and centre pt.
Extrim (handent "ABCDE" "1213,456"
Happy to provide code just ask.
