MTEXT not working correctly
Currently a 50/50 shot of MTEXT or TEXT or even TEDIT not functioning. I add a new MTEXT and it may work the first time or it may not. What's happening in almost every instance after giving the MTEXT command, i get locked into the command line instead of it leading me directly to the text box. I click on the text box to add my text and the characters are not being populated as i add text. I also cant delete text unless i highlight it and right mouse click, delete text. What seems to work occasionally is i will cancel the MTEXT command, and REGEN command to refresh the model space. This seems to work sometimes, but not all of the time. I have done some serious digging on this subject and have played with all of the solutions and nothing i do works to fix the issue. Anybody have a solution to this? I have started hand writing notes, texts, or added in PDF after printing.
Sometimes MTEXT works as intended.
  • What version of Bricscad is important. Never had problems.
  • Do you have all fonts on your machine, or some of them are located at some shared storage?
    There was a problem with a text editor in V21, related to huge number of text styles in a drawing, it was corrected in V22.
  • I currently have V25. I am missing some fonts, but they are not default fonts and are not used.
