Mleader - Underline Bottom Line spacing with Mtext
Dear All,
Is it possible to increase vertical spacing between a Mtext and an underline bottom line in a multileader style ?
Thank you for tou help
Underlining last line is easy part. If I understand the request.
Not sure about a Mleader but you may be able to edit the mtext part via a lisp to change line spacing, but that may only be good for 2 lines.
"LineSpacingFactor = 2.0"
If you have multiple lines may be able to use a Space with a character height set to change the gap betwen lines.
AI suggested there was a control for this \ls but can not find any documentation that matches AI is like that.
This seemed to work to put a big gap between 3 lines. By using a space with a bigger character height.
(setq obj (vlax-ename->vla-object (car (entsel "\nSelect a object "))))
(vlax-put obj 'textstring "AAA\PB\P{\H2.4x; \P}\\LB")If close post a sample dwg.
Thank you for your answer. I wish I could avoid Lisp code. Would it be possible to insert a block in a multileader instead to get the Mtext directly in the Multilideader. The Block will contain a Mtext that Users could modify ?
