Block with Attribute value = field = concatenated values of parameters
Dear All,
Is there any way (without any Lisp code) to get the value of an attribute as a concatenated value of 2 parameters (strings of characters).
Here you will find enclosed a block file I wish to modify. It contains 2 parameters made a designtable (dropdown list). I wish I could get the value of Attribute ATT3 = PARAM1.value&"-"&PARAM2.value.
Thank you for your feedback
BR
Here is the file
You can simply insert parameters as fields in the attribute value, but the parameters should be numbers not text. Text will not work.
This is add two atts and put in third example.
; add 2 attributes and put the value as a field into the 3rd attribute.
; BY AlanH(defun c:test ( / obj lst x )
(setq oldatt (getvar 'attdia))
(setvar 'attdia 0)
(command "-insert" "c" (getpoint "\npick point") 1 1 0 (getstring "\nEnter Att1 ") (getstring "\nEnter Att2 ") (getstring "\nEnter Att3 ") "-")
(setq obj (vlax-ename->vla-object (entlast)))
(setq lst '())
(foreach att (vlax-invoke obj 'getattributes)
(princ "\n")
(setq lst (cons (strcat "%<\AcObjProp Object(%<\_ObjId "
(vlax-invoke-method (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object))) 'GetObjectIdString att :vlax-false)
">%).Textstring>%"
) lst ))
(setq str nil)
(setq x (length lst))
(setq str (strcat "%<\AcExpr "
(nth (setq x (- x 1)) lst) " + "
(nth (setq x (- x 1)) lst) ">%"
(setq x 1 y 4)
(foreach att(vlax-invoke obj 'getattributes)
(if (= x y)
(Vla-put-textstring att str)
(setq x (+ x 1))
(setvar 'attdia oldatt)
(princ)
(c:test)0
