Data Extraction - Attributes from block as content of a Mleader
Dear All,
Is there any way without bLisp Code to extract attributes from blocks placed as content of a Multileader ?
TY
  • Hello.
    For multileaders, usually, the attributes are available in the Data Extraction Wizard window, on the Properties page - page 4 of 5, in the Attributes category.
  • Attributes that I have created in my block are not available in Page 4 of 5.
    My question was maybe not clear enough : The content of the Mleader Style is a block which contains attributes I wish to extract
  • Hello.
    Maybe I didn't understand correctly, sorry about that.
    I attached a video showing how I used DATAEXTRACTION to extract attributes from some mleader entties.
    This is useful to extract the values of the attributes in some mleader entities.
    If the task refers to editing the mleader style, then, indeed, an API (lisp , BRX) could be used.
  • I think answered elsewhere also, can write a custom data extraction lisp so should be able to include mleaders in that lisp.
    Without some idea of what you want objects and properties, no actual help.
  • Thank you Virgil. it works now. I used to work with Bricscad V22 and the attributes were not shown in the properties panel. I switched to Bricscad V26 and I can get them now.
    Thank you very much for your time
