BricsCad V14 Installation Files
Dear Forum
As we are renewing a PC and still want to use V14, can anyone share with us the installation files please?
Your help is much appreciated.
Thanks in advance
Kind regards
Did you contact Bricscad ? Being a older version they may not supply, Autocad/Autodesk does not for older versions.
I take it you have your ID Key, if you don't have that no idea how to install even if you get install software, You will not be able to turn on.
Same issue here. Bricsys is no longer offering the installation files of our version (V14) although we have a perpetual licence.
V14.2.17-2 has a file size of 139,416KB. That's too big to email or to post here.
There is send file software and its free, I use "Wetransfer". Give it a try.
