PickDrag
I just one dwg file in v23, Pickdrag setting to [0] Draw selection window using two points, is not honoured - it will only Draw selection window using dragging i.e. as [1]. Previously, on settiing [0], it would respond to whichever method I did. Other files in v23, no problem.
I copied all entities to a virgin dwg file, and did a Repair in Control panel>Uninstall or change a program - but it's still same.
Same file, and all files, in v24, no problem.
Any ideas?
It's rather curious, as PICKDRAG and PICKAUTO variables are stored in the registry and the selection window behavior shouldn't depend on a drawing. Could you attach this drawing to try?
It is rather curious - now it's behaving properly!
I was wrong to say "Previously, on settiing [0], it would respond to whichever method I did"
Well, let's hope it will work correctly further!
