Teigha.ModelerGeometry not found!
In the page:
we have the line:
using _AcMg = Teigha.ModelerGeometry; //Bricsys specific
but after the last update to 26.2.03 we have error:
The type or namespace name 'ModelerGeometry' does not exist in the namespace 'Teigha' (are you missing an assembly reference?)
I also tried with the new NuGet !
ODA have moved the ModelerGeometry namespace into a separate assembly now, but the new assembly is still empty, so we did not bother adding it. I expect we will eventually ship the new assembly, once it contains something useful.
I should add, if you're encountering a build error because of the unavailable namespace, you can temporarily define it somewhere in your own project. Following is an example C++/CLI code:
namespace Teigha {namespace ModelerGeometry { public ref class ModelerModule {}; }}0 -
I don't need this in my projects.
The problem is that on the main page of the .NET API the problematic definition appears.
I edited and changed the USING region.
I have a small service program that runs on all files and replaces/updates all files.0
