Error at modifying text height inside an dimension
When trying to manually adjust the height of text inside the mtext of a dimension using "DDEDIT" (any kind, linear, aligned, angle, etc) it does not make the change in height and it send an error message
"(if (ismechanical) (command "_AMPOWEREDIT") (command "_DDEDIT"))
: _DDEDIT
MText parsing issue (1)
An unexpected error occurred. The application became unstable.
It is recommended to save your work to a temporary file and restart the application."
It does not matter the style of the text nor the dimension style, i've tried in new drawings like in old ones. I don't know if anyone else have notice this, have the same issue, it's something to do with the last update or if it's just me.
It just happen inside the MT editing window inside the dimension, not when editing a normal MText (that's not part of a dimension)
Im running BricsCad PRO V26.2.03
