Missing project or central database
ScottC
edited May 25 in BricsCAD BIM
This message comes up constantly and is driving me crazy because I don't know how to get rid of it. I don't use BIM, but I tried it once - now it haunts me with this nag message. Do I have to reinstall Bricscad with a Modeling tier only? There must be a way to stop BIM from being active in my setup.
I have Ultimate 24.2.07 btw.
Thanks!
  • You may have setup a Bricscad BIM Project accidentally at one point.
    This will create some configuration and data files. Mayebe you deleted one of these.
    Look for a "project.bsyslib, project.ds$, project.dst, updatetime" files in your project folder.
    Remove/rename/delete these.
    Then Bricscad should not expect a BIM Project when you open your drawings.
  • thanks - I've deleted all the files like that that I could find. Will see if the msg pops up again or not.
    cheers
