Prompt History isn't long enough to show all of a (dumpallproperties) (solved: SCRLHIST)
Hello,
I'm trying to do a (dumpallproperties (car (entsel))) on a BIM window object, but the prompt history buffer doesn't appear to scroll back far enough to show me the entire output.
The properties in the various categories appear to be arranged alphabetically, so I'm pretty sure I'm not able to scroll all the way back - I get to "Rotation…" in the category just above BIM Properties and then the history ends.
Any help appreciated!
EDIT - Found the answer. SCRLHIST defaults to 256. I bumped it up (and then restarted Bricscad) and I can get the entire dumproperties now.
  • You should also be able to use LOGFILEON it will then record eevrything that appears on command line, you start it then use LOGFILEOFF to stop. It is stored in the "Temp" directory under OPTIONS FI:ES. The main advantage is you can open a text file and read.
