Creating a annotative scale block that syncs with the viewport scale
This is actually coming from the fact that we recently switched from Microvellum OEM (AutoCAD) to Microvellum BSB (BricsCAD). Our scale block on in our template that was created in OEM just doesn't work in BSB. It was setup to automatically sync to the viewport scale. Now it just revert back to 1:1 scale every time you save or publish. Full disclosure, I am a complete rookie with blocks in general. So, I could sure use someone's help with setting this up or fixing the old one if that is even possible.
Can you post a dwg with the block use wblock to export out just that block.
That's a handy idea
Here is what was created in AutoCAD.
