CAD-Lisp support for Geany
For those looking for a cross-platform editor, I recently added CAD-Lisp support to Geany.
As I am doing more and more development work on Linux, I wanted a single editor and workflow for both Linux and Windows.
Features include:
  • CAD-Lisp file type recognition
  • Syntax highlighting for BricsCAD Lisp code (and OtherCAD)
  • Custom function highlighting
  • Improved brace matching
  • Linux and Windows support
Documentation and download:
https://vanderworp.org/notes/cad-lisp-support-for-geany/
The CAD-Lisp wordlist is based on work by Torsten Moses.
  • Thanks a lot.
    Blade is still so unstable on Linux…
  • I can't thank you enough!
    Geany is the way to go - thanks for pointing me to it!
    Roumen
  • ALANH
    edited August 27
    I use Notepad++ which has Lips support, I am on windows.
    One option to consider for Geany, in Notepad ++ you can select code then run that code in your CAD. Which is very handy. It uses an ActiveX addon.
  • Thanks for the suggestion. I can certainly see why running selected code directly in CAD is useful.
    I looked into how this could be implemented for Geany. On Linux/X11, the selection could be written to a temporary Lisp file and xdotool could activate BricsCAD and load it. That would work, but it is GUI automation rather than a proper interface. It depends on X11, is likely to break under Wayland, and would require a completely different implementation on Windows, such as ActiveX.
    This would therefore introduce platform-specific and rather fragile code into what is currently a straightforward language-support module. I prefer to keep the module portable and concentrate on solid CAD-Lisp editing support: syntax highlighting, symbols, completion and related editor features.
    For running selected code directly in CAD, Notepad++ with its ActiveX add-on remains the better solution on Windows. Linux users who really want similar behaviour could still create a local Geany command or script tailored to their own CAD and desktop environment.
