VISRETAINMODE
Hi there,
I want to switch from AutoCAD to BricsCAD. In AutoCAD there is a variable called VISRETAINMODE which controls what XREF layer properties are updated in the host file on XREF reload. I found this discussion from 2024. Is there a better solution in 2026 in BricsCAD?
