multileader
I was using the multileader command with no problem with normal results,
and a minute later with the same drawing I try to use the multileader and
all that occurs is a box to enter text with no line connection (tail) to the item.
So after an hour of searching for the problem no answer.
How does the command line output of MLEADER command look on your side? If the 'Specify leader landing location' is current option or 'Specify first corner of text or', you can choose the 'leader arrowHead first' option in the list:
: MLEADER
Specify first corner of text or [leader arrowHead first/leader Landing first/Options] <Options>: H0 -
Lyubov thanks a bunch for your help.
You are welcome )
