Base quantities for BIM Doors
Is it possible to add Base Quantity attributes to the doors ?
I added them with the XML file, I can see them in BIM properties and yet I can t see them when I export an IFC, is there a way to make it work or a work around ?
I use Bricscad BIM 26.2
Hello.
In Bricscad, base quantities are calculated only for BIM entities based on 3D solids.
For blocks, base quantities are not calculated.If the value of a property is not initialized, then the property is not exported to IFC.
