BricsCAD crashes when switching from model to paperspace
Quite often when I'm in paperspace and double click in the viewport to go to model space or via vpmax BricsCAD Lite crashes which is quite annoying.
I'm working on a MacBook Pro 2018
Has anyone else this problem and can it be resolved.
  • I think it's worth to report the crash via Support request.
  • I had a similar issue too and I have told it to the Support team.
    MBP M3
    It happened (in my case), when I was adding/modifying/deleting measurements annotations in model space, and then entering a viewport in paper space.
    It should be fixed in a future release hopefully, they didn't give me a timeframe.
    I have learned to keep the culprit files in a separate instance, and anticipate the crash by saving the file before entering any viewport.
    It is really annoying and wastes time, but at least they know about the issue
