Array within Dynamic Block
KobeBean
edited July 16 in 2D Drafting
Hello, I have a dynamic block with multiple visibility states. I want to apply an array action to an object within one of the visibility states. However, when I try to do this, the arrayed objects appear on all the vis states. I only want it to appear on a single visibility state. Note the source object and array action are only visible in the one visibility state. Please help, how do I apply the array to only 1 visibility state?
Note: I am using V26 Experimental mode, so could be a software issue.
  • Hello.
    A solution would be to make the source entity, the parameter, and the action visible in only one state.
    Inside the block editor, the buttons Visibility Mode, Make Visible, and Make Invisible can be used to achieve this.
    If the source entity needs to be displayed, but without the array, then a separate similar entity needs to be created.
    It is not possible to display the source entity but not its array.
    The array is dynamic and all items in it use the settings of the source entity.
    I attached a basic sample drawing.
    You can replace the circle with a square to experiment with how the "similar entity" concept mentioned above would work.
