Can You Add A Command, Like 'PSPACE' To The Quick Access Toolbar?
I'm just wondering if there is a way to add a command, like 'PSPACE' for instance, to the Quick Access Toolbar.
I usually don't mind typing in commands and I actually prefer it in a lot of cases, but when I'm trying to get out of a viewport I think I'd prefer just hitting a button up on the QA Toolbar.
Hello.
The PSPACE command doesn't have a default tool (button) created for it.
So, the first step would be to create a tool that uses this command.
Then, this tool cad be dragged and dropped on a toolbar, like Access, or Access3D.A tool can be created as described in the article linked below.
The main article is "Customize dialog box".
To insert the new tool into a toolbar:
- Activate the Toolbars tab in the Customize dialog box.
- Expand one of the toolbars.
- Drag and drop the tool on the toolbar tree at the desired position.
Thank you Virgil, that worked perfectly!
