Automatic extend of an arc
Hi guys,
I would like to create a LISP, but even AI has no clue. I have 3 2D objects - 2 lines na an arc. When I select all the 3 objects, the code should test if the arc crosses or touches the lines. If it doesn´t , the arc should extend it´s end(s) to the line(s).
There are 3 cases on the picture:
Thank you.
SOLVED.
@JanBeno Glad you got it sorted. Did you want to share how you did it in the end, in case anybody else has the same conundrum?
What is the LISP, could you share @JanBeno , thank you!
Hi, this is the script. Tested on Bricscad BIM V26.1. For now, it works only with and arc and lines. I made it only as a testing sub-script.
