Multi page PDF don't print
Recently I've migrated across from AutoCAD and having trouble with the Multi page PDF.
It creates it OK, can view it in Acrobat reader as normal but when i go to print it, it throws and error message.
But, strangely, i can print each page individually?
Have lowered all the output settings, tried to print as an image, printer driver is updated etc.
Anyone else had this issue or any clue on how to fix??
  • Do you create multi page PDF in BricsCAD then print to paper from Acrobat? If separate pages are printed correctly, did you try to output separate pages then join them (as I know, Acrobat can combine files) and print?
  • ALANH
    edited August 13
    Seperate pdf's can be joined into one pdf, using GHOSTSCRIPT, I have a plot lisp that does just that plots single pdf's from a range of layouts then joins them all back into one PDF, all from within the lisp. You will need to download Ghostscript and edit code to suit. The code here must have the window variables changed for the title block in a layout. Save Multi getvals.lsp to a support path or put full path into (load " it can be used in any lisp program.
