Parametric Blocks Turn Anonymous After Adjusting Parameters
I have an issue where every parametric block I've created turns into an anonymous block after I adjust a parameter (stretch, rotate, flip, etc.), thereby making the attributes unable to be edited. What is causing this and how do I stop it from happening?
Well…after a bunch of searching and asking AI…this seems to be the way BricsCAD is coded. The only way to change attributes in a parametric block is through the properties panel.
Yeah, as soon as you change something, a new block is created. ATTEDIT does not work?
It does, but it is the most un-user-friendly command I've ever used.
