V27 Field-editing causes instant crashes
In V27, when editing a FIELD-expression I select an object, and choose the area value. I then configure the area-value. When I copy the FIELD-EXPRESSION to paste in the Formula-field (to divide by a number for m2-value), firstly the field-expression isn't pastable the first try. With a second paste-action the formula is pasted, but the FIELD VALUE isn't updated.
When exiting the FIELD-dialog, the program crashes.
In V26 everything works fine. So I need to revert back to V26 as this critical bug makes V27 unusable for me.
Already filed a bug-report for this. But thought I should mention it here as well.
